Since I have GND in the outer bigger frame I made a small frame for VCC and hooked it up to the two VCC pins on the CPU. I also added two 100n caps between VCC and GND.
![](https://cdn.hackaday.io/images/6316721549628774152.jpg)
I discovered that I don't have any thru-hole caps in the pF range so I had to improvise a bit by soldering two SMD caps between the pins of the crystal and then hook up a ground wire between the caps.
![](https://cdn.hackaday.io/images/5999481549628962970.jpg)
After adding some 10K pull-ups to the inputs of the CPU that must be held high while running I could got a nice waveform at the clkout pin and a lot of randomly-looking toggling at the combined address/data-bus pins.
![](https://cdn.hackaday.io/images/1108511549629158644.jpg)
So it seems that the CPU is not completely dead at least :-)
