Been spending some time mangling a CPU power supply to provide the 5 Volts to supply the TP 4056s. Added a switch and an LED, waiting on 10 watt 5K resistors, found a source for $0.26 each only got 5 for now, hopefully be here fairly quickly since they are not on the transpacific boat.
