I spent spent quite a bit of time doing video and getting 2 boards to work on the charging tower. I have already started on 2 more. Sadly it's spring time and the honey do list for the outdoorzy stuff is growing in prior per the honey. I just need to get motivated now to finish it up with a total of 4 boards which I believe the cpu power supply should be able to handle.
