This is the current version of the housing, now with labels on the buttons. The button size is also increased for better pressing feedback.
Outer diameter of the housing now is 12.5mm. Nearly the same as the rubber grip on the RT Tip.
![](https://cdn.hackaday.io/images/7264291551020676730.jpeg)
A project log for USB-C-PD Soldering Pen for Weller RT Tips
Small and powerfull controlling unit powerd from USB-C-PD
