In progress now. So far, it is going rather similarly to a previous one, even though that previous one was done on defunct circuit.
The threshold voltage is now rising again.
UPDATE: finished.
Unprocessed data available in files: TORTURE2.TXT. Note: torture currents are chopped with 50% duty cycle, so the average currents into gate are half the indicated values.
Kinda similar to what I got with broken circuit. Except, this time:
* fresh transistor
* final current was 1 uA, not 0.3 uA
* I almost reached the end of the process =)
Wow... A single MOSFET could create a very very slow time constant... of course, temperature dependent :-D
