Overall torture kinetic
Slopes
Rate of threshold voltage change is not exactly proportional to gate current, but close to being so.
Post-torture drift
Surprisingly little drift. But the mosfet is likely very much damaged, so it doesn't make much sense.
I have only one more fresh mosfet remaining for experimenting (same model, IPD10N03LA). I plan doing a negative voltage torturing for comparison with positive. After that, I either order more of them (if I can), or move to experimenting with other mosfet models.
UPDATE: found one more!
