All your base are belong to us.
A project log for Christine's Blooming Rose
3D printed, heat formed, servo actuated blooming, Dotstar module lit, rose.
masterofnullMasterOfNull 02/25/2019 at 09:450 Comments
Modeled the base containing the servo/Arduino.
The print head caught the part very near the last layer which failed the print.  It was almost salvageable, but not quite.
It's all good though, because the servo slot I modeled was way too tight anyway, and I never reconfigured Cura from the settings I had used for the nylon petals.  The result was over-extruded and 30 degrees over-temp for the printing of PLA.  I'm surprised it worked as well as it did.
Remodeled.  Sliced. Reprinting.
