One leaf, bigger socket.
A project log for Christine's Blooming Rose
3D printed, heat formed, servo actuated blooming, Dotstar module lit, rose.
masterofnullMasterOfNull 03/05/2019 at 06:280 Comments
Remodeled the stem so it has one leaf instead of two.  Makes assembly a whole lot easier as otherwise you end up soldering a Dotstar in mid air.  That sucked.
Also modeled a cover out of something not transparent.
