The idea for this sonde is a minimal cost system that transmits data to ground from at least 5000ft. The device should be recoverable and reusable.
The desired measurements are as follows:
- Temperature
- Pressure
- Humidity
- Wind Strength
- Wind Direction
P/T/H can be accomplished with a single chip such as the BME280.
Wind measurements can be derived with some accuracy using a GPS and integrating the movement of the system as it falls.
The descent rate of the system will provide the time for GPS movement, but with some caveats; the slower the sonde descends, the more it will drift. A balance needs to be struck between ease of retrieval and measurement quality.
