Last version, I promise. Bharbour was right, it gets quickly gets very complicated. Nonetheless I needed the ability to talk to multiple instruments and at least two device channels for my test setups.
This version adds both along with some bug fixes and optimizations. Existing config files will need some updating to work properly but the same general syntax is used. The zip contains a working example config.
