xmas id badge (flair)
a bit of blinky xmas tree flair for an id badge or an ornament.
Public Chat
my better half had to work this xmas and so i put together a little something to put on their badge at work. sometimes a smile is worth the cost of overnight shipping because you procrastinated and waited til the last minute.It's based on an atmega328p (vqfn-28) and powered by a 1220 button cell. I'd like it to last a little while by going to sleep after it does the blinking. My apologies ahead of time as this is my first time using hackaday.io and github. Everything was hand soldered. I used a paint stripping heat gun (go big or go home) to solder the avr. It was programmed using an atmel-ice. the programming header was removed and the pads covered with kapton before the battery was inserted. that interference was just a design compromise to get the size down.
See shared OSHPark project.
Graphics Interchange Format - 1.05 MB - 02/14/2019 at 23:02
Preview
  • 1
    Step 1
    solder qfn avr on back side
  • 2
    Step 2
    add other components on back side
  • 3
    Step 3
    add led's to front side
View all 10 instructions
davedarko wrote 02/15/2019 at 11:03 point
that's a cute tree!
