For a long time 2 axis support was always promised and was partially implemented but just now I finally got an actual FFB joystick to test and improve it with.
And to my surprise even the TMC4671 which was never tested in a dual configuration worked almost perfectly after some small modifications.
The ODrive CAN bus implementation caused more time debugging than the TMC4671 :)
See for yourself in the video below.
Yannick (Gigawipf)
