While there have been unofficial builds with support for the MyActuator CAN motor drivers it was not officially implemented until now.
The protocol is unfortunately a bit limited only allowing for <100Hz updates but it might be improved by the manufacturer in the future.
For testing the new motor driver support class a demo build of a compact RC style transmitter with the L5005 motor was documented:
The RMD motor mode will be available in firmware v1.16.0.
3D print files for the controller:
Original controller design: https://www.printables.com/model/1074755-rc-style-ffb-controller
Modified files: https://www.printables.com/model/1172877-rc-style-openffboard-controller-with-rmd-l5005
