OBSOLETED
Google Sheet with app script to pull out just the unshipped ones. For download and import into shipping software.
I went to use this yesterday and it came up blank. No time to dig into it I went to the website to dowload the whole list the edit out the shipped stuff. To my pleasant surprise Tindie have added a selection dialog to the download function including the ability to download just unshipped stuff.
So this project has served its purpose and is now dead.
No orders comes out with headers but no orders.
If there is an error it says "No orders". I need to update it to display the actual error.
Pull unshipped orders from Tindie API
Because the website doesn't offer it, and Endicia will make duplicates
Copyright 2019 Alastair Young
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,
modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
function onOpen(e) {
var sheet = SpreadsheetApp.getActiveSpreadsheet();
sheet.getSheetByName("Data").clear();
var url = 'https://www.tindie.com/api/v1/order/?format=json&shipped=false';
var username = sheet.getRange("Settings!B1").getValue()
var apikey = sheet.getRange("Settings!B2").getValue()
var options = {
'muteHttpExceptions': true,
'headers' : { "Authorization":"ApiKey " + username + ":" + apikey }
var response = UrlFetchApp.fetch(url, options);
var json = response.getContentText();
try {
var data = JSON.parse(json);
} catch(err) {
sheet.getRange("A1").setValue("No unshipped orders");
return;
var values = [
"number",
"date",
"email",
"shipping_name",
"company_title",
"phone",
"shipping_street",
"shipping_street_2",
"shipping_street_3",
"shipping_city",
"shipping_state",
"shipping_postcode",
"shipping_country",
"shipping_service"
for(var row in data.orders) {
var newRow = [];
for (var key in values[0])
if (values[0][key] == "shipping_street"){
var address = data.orders[row][values[0][key]].split("\n");
for (var i=0; i<=2; i++) {
if (address[i]) {
newRow.push(address[i]);
} else {
newRow.push('');
} else if (values[0][key].indexOf("shipping_street")>-1){
continue;
} else {
newRow.push(data.orders[row][values[0][key]]);
values.push(newRow);
var result = sheet.getRange("A1:N" + values.length).setValues(values);
Use the chrome browser. No idea if others work for this.
https://docs.google.com/spreadsheets/d/1KSlpx2WAQyn0OXfDoK2Z6t9wVK6rqHWWJI-ZzS8JLV4/edit?usp=sharing
Open the sheet and under the File menu select "Make a copy..."
name it whatever you want
Select Tools -> Script Editor
this will open another tab. Go into that tab
look at the code to verify I am not installing anything nasty
Select Edit -> Current Project's triggers
this will open another tab in the G Suite Developer Hub
select "Add trigger" in the bottom right
Choose the function "onOpen" to run in the "Head" deployment in the "from spreadsheet" source and event type "on open"
select Save
it will prompt you to choose an account and allow permissions. choose the current account and approve the access.
go back to your sheet and select the Settings tab.
enter your Tindie username and api key in the indicated spots. You get the api key from the "Seller Tools" tab in your Tindie store
