Upgrade from Hacked to Hackable
A project log for Low Power High Accuracy Weather Station
'Professional' wind instruments are mounted high on a pole in an exposed location with LoRa data transmission
goat-industriesGOAT INDUSTRIES 03/08/2019 at 11:250 Comments
The previous version of this project was hacked on a spare PCB I had lying around and tested in the field for a couple of years. This enabled me to create a 'proper' version that, rather than being hacked is now custom made but still hackable with facility to use the generic Chinese wind instruments and add other sensors if so required.
