A simplified version of the board with the microcontroller and a set of LEDs to stand in for the actual coil driver.
Next step is to build a 74595 shift reg board (configured as a stand in for the MIC5841 to be used in the final project) with 6 LEDs to stand in for all 6 coils. Then the shift-register code can be written (it shouldn't need altering for the real-deal).
The software is over at GitLab: https://gitlab.com/edgeeffect/attiny24a-mic5841-magnetic-stirer/tree/4-LED-test
