HASP 0.37 release
Stability and performance improvements
ESP8266 code v0.37
- Updated ESP8266 Arduino core to 2.5.0, which comes will a whole truckload of stability and performance improvements
- Major improvements for LCD firmware updates to improve reliability and update speed
- Re-enable mDNS services with LEA MDNSResponder
- Improve user experience when MQTT client cannot connect to broker
Home Assistant Automations
- Updated JSON sensor to new format after changes in 0.85
ESP8266 Update Procedure
If you're using the AutoFirmwareUpdate automation your devices should pull this update at 3:00am. Otherwise, log into the admin web page and you can pull the update from the firmware page.
Home Assistant Update Procedure
Run the deployhasp.sh
script to pull down the updated automations using one of the guides below:
Links for more HASP info
- Main documentation page
- Buy HASwitchPlate PCBs - strongly recommended for safe assembly. Buy them from me or download the gerbers and send them to your favorite short-run PCB fab.
- Buy an assembled device ready to install if the build process seems intimidating
- HASwitchPlate Discord chat
- HASwitchPlate Reddit community
