Arudino compatible thermostat
Thermostat with InvIoT U1 (arduino compatible).
By using the InvIoT U1 and a 4 relay arduino compatible module, I build a thermostat for heat/AC. It works with or without force air (FAN). There is a 24 zone temperature setting.
InvIoT U1 at kickstarter
There is a 24 hour temperature zone setting. Works for heating and A/C, with a force air or without a force air. A U1 and a 4 relay module is needed.
thermostat.ino
not so many comments. Sorry not so much time!
x-arduino - 15.78 kB - 10/16/2016 at 20:53
Download
  • 1
    Step 1
    Setting up, connect relay, upload sketch
    1. Download the library for the U1 model at InvIoT.com/download
    2. Load the sketch in your arduino IDE. Go to menu file/examples/InvIoT/applications/thermostat
    3. Set the pins depending on the relay module you have got.
    4. Connect the wires to your heater/AC unit.
    5. Upload the sketch
    Setup menu:
    Press the home button on U1 to set up the menu.
    First setup the time and the unit that you are using (C / F).
    If you like set time zones.
    Used at your own risk. All the info, software and hardware is "AS-IS".
View all instructions
