According to the Moell T-hunting book the 1n4148 diodes introduce more switching noise and more potential for cross-modulation from strong signal sources. A quick look at my friendly non-local distributor shows that there are SOD-323 PIN diodes for about $0.40 and even cheaper ones in different footprints. So in a four antenna system I'm using eight diodes. I'll go cheap on something else. Off for diode shopping... Or more PCB redesigns....
