Safety PSA
A project log for Electric Snowblower Conversion
Using a 1979 Ariens chassis, but replacing the small engine with a DC motor
ryanRyan • 02/19/2019 at 17:30•0 Comments
In case anyone is wondering, metal tape measures can carry a surprising amount of current .... and make an awful noise. I measured less than an ohm of resistance over 6 inches.
If you bridge the terminals of your 48V battery with a metal tape measure, you might need to change your shorts afterwards.
