Motor and Battery Wiring
A project log for Electric Snowblower Conversion
Using a 1979 Ariens chassis, but replacing the small engine with a DC motor
ryanRyan • 03/01/2019 at 18:29•0 Comments
The batteries will be mounted directly above the motor for better weight distribution. If you look under the battery, you can see I made a 3 to 1 parallel adapter so I can run 1 to 3 packs without needing to rewire.
That's 3 XT90 connectors that come out the other side to a single XT90. I used brass bar to solder the connectors together, then covered them in electrical tape.
The power then goes to the Toyota Prius contactor, and to the motor. I upgraded the wiring going to the motor brushes from 18AWG to 10AWG. The windings on the inside are a work of art, they look like they can handle a lot more than their rating.
