Changing the nozzle of a 3D printer isn't so easy when hotend is cold because filament remains so if you try to screw out the nozzle with power it could be damaged. It is recommended to heat the hotend.
It's easy to clean a 3D printer nozzle when it is heated by a soldering iron.
