Basically I forgot I even had an account here until I got an email. The PCB has been redesigned about 25 times. Finally got a one sided design I'm happy with. The PCB has been milled and drilled, all of the components soldered. Everything works as intended. There will eventually be a video on the milling and drilling of the PCB, but may be a week or two.
