Today we are going to take a look at an all-in-one module which is very much useful in rigging up a quick UI hardware interface for any project that we make in the future. Watch the video on my channel to see the board in action!
Let's start with the project now!
Checkout UTSource for electronic components for your DIY Projects with free shipping: https://www.utsource.net/
To make this you will need an ESP8266 board and you can also add a battery if you want.
I suggest to use a board from DFRobot with this module as the pinout will be compatible and you will face no issues anywhere, I used Firebeetle board from DFRobot as it has on board battery charging and monitoring solution.
I would also recommend using a PCB to make some project using this module so that adding battery/OLED display/switch/esp8266 doesnt remain difficult. You can order your PCBs from PCBWAY as they offer 10 PCBs for just 5$. Check out their online Gerber viewer function.
