With the addition of 32-bit wide, 16-megabyte DRAM, Tiny030 is capable of running a varieties of application software quickly. In this project we'll rerun the EhBASIC and memory diagnostic of Stage 3, add a new memory diagnostic for 16-meg DRAM, and do a benchmark of EhBASIC running in DRAM and compare that to EhBASIC running in 8-bit RAM.
The existing ROM monitor runs fine in stage 4 hardware. It now can access memory located from 0x1000000 to 0x1FFFFFF.
![](https://cdn.hackaday.io/images/6164151551716522362.jpg)
I wrote a memory diagnostic to test 16 meg of DRAM
![](https://cdn.hackaday.io/images/5961371551716596377.jpg)
EhBASIC is relocated to 0x1000000 and allocated 6 meg of RAM. I measure the time it takes to run the ASCII mandelbrot at 27 seconds. Compare that to 45 seconds running in 8-bit RAM of stage 3. The improvement of 32-bit memory over the 8-bit memory is not as great as I would expected. I believe one reason is because the 8-bit RAM is running at zero wait state while 32-bit memory has 2 wait states for the slower DRAM circuitry.
![](https://cdn.hackaday.io/images/7711571551797537346.jpg)
