The first stage of this project began with the decision of what processing unit to use. It was decided that a Raspberry Pi will be used because of the share volume of accessories available and Raspberry Pi's typically use python as a coding language. The Raspberry Pi is then connected to a 7" touchscreen via GPIO pins, and display tape. The Raspberry Pi can be screwed directly onto the back of the touchscreen, saving space within the companion robot.
