A low cost simple project
It is a little complex.
I suggest you have a look at this project first : NodeMCU
Go to here to customize your own firmware.
Then you can see here to know how to burn firmware into D-duino.
I put my code on my github:
https://github.com/lspoplove/D-duino/blob/master/L...
Using Esplorer tool to write LUA is a good choice.
LUA is as simple as Arduino.
Please have a fun!
View all instructions
J_Ray
Daniel Öster
Alexander Ryzhkov
Omar Mekkawy
Yes, delete it Cancel
You are about to report the project "Movable WiFi scanner", please tell us the reason.
