I promise I will get things done in these next two weeks. I have decided to leave every version of the bot uncovered, and then make a special shell for each one. The first shell that I will be making for this project will be Gray Fox (The Cyborg Ninja) from Metal Gear Solid. I have been a fan of the specific game and entire series for years, and I would like to pay homage to the series with this shell. I highly recommend the series if you have not heard of it already. Don't worry, this will not be taking time away from the rest of the project, it will be completed after the actual robot is complete, or at least the first version of it is. I will also be taking suggestions for shells for future versions. Again, this is just a little add-on, not taking time away.
