TRIPLE CNC MACHINE
In this video, we will try to make a simple cnc machine with you. “ A SIMPLE HOMEMADE TRIPLE MACHINE “.
We will try to make a simple cnc machine with you. “ A SIMPLE HOMEMADE TRIPLE MACHINE “. With this cnc machine you will be able to do 3 different jobs.
-Engraving with Dremel,
-Laser cutting
-Drawing with pen
With the new drawings that we designed as a plug-in, it will be quite simple to use cnc. All you have to do is remove the parts we share in the video description from your 3d printer and provide the necessary materials. Our design is quite simple. No unnecessary material. No unnecessary wires. Our design is quite simple. No unnecessary material. No unnecessary wires. In our video, we tried to show how to do our cnc machine in the finest detail.
stl.rar
RAR Archive - 127.83 kB - 02/26/2019 at 20:06
Download
  • 3 × NEMA 17
  • 12 × LM8UU LINEAR BEARING
  • 3 × 608ZZ BEARING
  • 1 × Arduino Uno
  • 1 × Blue laser module laser engraving and cutting TTL module
View all 7 components
  • 1
    Step 1
  • 2
    Step 2
View all instructions
