04/21/2019
Well I tried various side mounting schemes and after a lot of fussing decided that top mounting (like here) is really the way to go with such a small box. The problem is that the PMMA window designed to mount over the VL53L0 ranging sensor has a step to allow flush mounting to the outside case and to allow gluing or sealing along this stepped edge for a more or less hermetic seal.
Machining such a complicated shape onto the side of the box proved impossible. But doing so on the box bottom was relatively easy (see above, thank you Greg Tomasch!). I also redesigned the VL53L0 carrier board using a 2-layer design so I could have it made at OSH Park in 0.8-mm thickness and I reduced the width a bit thinking it would be easier for side mounting. The pcb width is now the same as the PMMA window width. The PTHs are designed to be aligned with those on the main board as I was thinking I could use some sort of board-to-board mezzanine connector with the side mounting but I have fallen back to simply soldering wires.
I did test the new window location with the old rig by taping the carrier board over its top to hold it in place (the fit is pretty snug though) and placing the main board in its usual place. The main board and carrier board nearly interfere so switching to the thinner carrier board design is really a must for bottom mounting. Although I could stand the main pcb off with washers or something.
I ran the test a few days with the device mounted to the underside of the recycle bin lid and got this:
One problem I had was that when I opened the lid the device would often reset as denoted by gaps in the record. This happened because I didn't solder the coin cell battery to the pcb. So when I opened the lid the battery connection would often fail, power would be interrupted and then sometime later would be re-established and the device would reset and start reporting again. At least, this is what I think was happening. I am going to repeat the test over a longer term using the new VL53L0 carrier board and with the coin cell battery soldered to the main pcb to see if I can get weeks or months of continuous record. I am also curious as to whether the device mounting with VHB foam tape will survive the weekly bin emptying by the garbage service. We'll see....
Addendum: I replaced the VL53L0 carrier board and soldered the coin cell battery onto the main board and put everything together:
