The last few chips were added this weekend to complete the GPU functionality. The system had been stabilized to work with the 32 MHz dot clock and the initial testing started with that. Unfortunately things didn't work at all once the font ROM was engaged!
Up until now the GPU has been kept in its blanking state for CPU testing. This is where the GPU addresses the RAM location 0x1FFFF, which returns the same byte on every GPU cycle. This means the ROM data bus alternates between the CPU code/ALU result, and a single value. This all changed once the GPU was brought out of the blanking state. Now there is the full entropy on the bus with alternating code/ALU and glyph data. This creates a much more complex set of signals and the already noisy bus became too unstable to latch valid data.
Another issue is the memory speed. The 32 MHz dot clock requires memory access time of better than 50ns. The NOR flash was measured at around 35ns in the blanking state, but couldn't keep up when the font lookup was also being processed. Reducing the clock to 25 MHz brought things back under control, but only just. There is still a lot of glitching mainly caused by noise from the following rat's nest...
The video loop described in the previous log was updated for the slower clock to produce 65 columns by 38 lines of text. The video memory is not initialized, so the color and text data is just random. The following photo shows this data when displayed on the CRT:
The CRT works great and the video signal is crisp and well defined. This is unlikely to the typical display method, so the signal was also examined on an LCD. This is where things start to get interesting though. The 38.4kHz/60Hz video signal is treated as SVGA and assumed to come from a 40MHz dot clock. This means the LCD will oversample the signal and record all the timing glitches when one color changes to another.
This effect can be seen in the following detail from the LCD:
This ghosting was anticipated and the RGB bits were passed through a final set of flip flops to make sure all the bits change simultaneously. However, this did not solve the problem since the logic level rise and fall times differ. The final stage of flip flops made very little difference to the quality of the signal. In fact the version with the flip flops displayed additional noise caused by crosstalk with the other flip flops on the chip.
Below is the same section of color text. The version at the top was resampled by the flip-flops, while the version on the bottom is the raw output direct from the 2:1 multiplexer.
These observations have been taken in to consideration for one final update of the schematic. Everything except the audio and serial communications has now been verified. It is getting harder to test though and full speed testing will not be possible with the breadboard. The plan is to now proceed with the PCB layout and then continue testing when the rev 1 board is available.
