The first hardware kit of the project is coming! You can pre-order it at https://www.makerfabs.com/voicen-linear-4-mic-array-kit.html
The kit named VOICEN Linear 4 Mic Array lets you build a smart speaker from scratch. It can run a variety of voice assistants such as Amazon Alexa, Google Assistant, MyCroft, Snips Offline Voice Assistant and Baidu DuerOS. It supports AirPlay and UPnP/DLNA. You can turn it into a music box with Mopidy and MPD, or use it to automate your home with Home Assistant.
Specifications:
Applications:
Yihui
