If the RPUpi were to be integrated onto an RPUno, I would want it tested with a self-test.
https://github.com/epccs/RPUno/tree/master/XcvrTest
That was a lot of effort; the good news is that it should mostly copy to my other boards which I plan to gradually integrate this into (and then ditch all sorts of headers). The 40 pin R-Pi interface will be my path forward, I have grown comfortable with what the R-Pi foundation is doing.
picocom -b 38400 /dev/ttyUSB0 picocom v2.2 ... Terminal ready RPUpi Transceiver Test date: Jul 11 2019 avr-gcc --version: 5.4.0 I2C provided address 0x31 from manager SMBUS cmd 0 provided address 49 from manager MISO loopback to MOSI == HIGH MISO loopback to MOSI == LOW SCK with Shutdown loopback == HIGH I2C Shutdown cmd is clean {5, 1} SCK with Shutdown loopback == LOW I2C Shutdown Detect cmd is clean {4, 1} Testmode: default trancever control bits I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: read Xcvr cntl bits {50, 0xE2} PWR_I /w no load using INTERNAL_1V1: 0.024 A Testmode: nCTS loopback to nRTS I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xA2} Testmode: read Xcvr cntl bits {50, 0x22} Testmode: Enable TX pair driver I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xF2} Testmode: read Xcvr cntl bits {50, 0xF2} PWR_I /w TX pair load: 0.044 A Testmode: Enable TX & RX(loopback) pair drivers I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xD1} Testmode: read Xcvr cntl bits {50, 0xD1} PWR_I /w TX and RX pairs loaded: 0.066 A RX loopback checked Testmode: Enable DTR pair driver I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xE6} Testmode: read Xcvr cntl bits {50, 0xE6} PWR_I /w DTR pair load: 0.044 A [PASS]
