The PCB for the three mouse buttons. The wood parts are ready.
The hole in the middle is "per design". I've left an empty space that later I can use to fix a palmrest if needed.
The wood piece used for the three buttons.
The wood piece fixed on the metal plate. Double side tape and a part of a label. Stable and flexible enough.
