Cheap, check
Easy to solder, check
Compatible with I2C wings, check
Compatible with (most? ) SPI wings, check (not using SPI pins for ADC)
Compatible even with ESP8266 feather, check (solder jumper for speed control needed)
If you need it urgently for a project, contact me for BOM/schematics (still under testing though).
