You guys!
I just discovered the flux_led python library. It's compatible with almost all cheapo smart bulbs including my magiclight bulbs. This is a game changer! I can use this script library to directly control the bulbs from my pi zero instead of using IFTTT as a middle man. This had loads of benefits so I'm taking some time to rewrite my script. It will be more code but should be totally worth it.
Sean
