Better code!
A project log for Smart switch for hubless smart bulbs
A switch to turn on, off, and dim hubless smart bulbs
seanSean 03/26/2019 at 05:120 Comments
You guys!
I just discovered the flux_led python library. It's compatible with almost all cheapo smart bulbs including my magiclight bulbs. This is a game changer! I can use this script library to directly control the bulbs from my pi zero instead of using IFTTT as a middle man. This had loads of benefits so I'm taking some time to rewrite my script. It will be more code but should be totally worth it.
Rich text editor
