Small test setup
A project log for Mendeleev
Interactive Periodic Table for KULeuven
wim-van-goolWim Van Gool 05/08/2019 at 17:050 Comments
We've managed to assembled the first 3 boxes with electronics in the small test setup. The concept works as intended. The communication test with the BeagleBoneBlack using the Bernardo cape was also successful. The sensitivity of the capacitive touch sensor is also increased so the presence of a hand is detected from a few centimeters in front of the glass. The glass itself is a triple layer museum glass panel of almost 3cm thick.
