Over on Discord, @Xark recently did some work on porting some old dhrystones to the rosco_m68k, which gave a feel for the performance of the board for the first time, and the results are encouraging! In Xark's words, we "blew the doors off an outdated Dhrystone text file found somewhere on the Internet" :D
Obviously these are to be taken with a hefty grain of salt as they're hardly "fair" - we're using a much more modern compiler than was likely available for any of the other machines on the list, and we also don't have an OS to get in the way. To try and make it a more even fight we did limit the GCC optimisation to -O1, which feels like it should be roughly on-par with the optimisations that would have been done by the compilers in use at the the time the other machines were benchmarked.
To see how the rosco_m68k stacked up against other machines of the same era, we ran the benchmarks with both 8MHz and 10MHz system clock. The results were thus (further down the list is better):
Last updated 06/06/2020 by Xark *----------------DHRYSTONE VERSION 1.1 RESULTS BEGIN-------------------------- * * MACHINE MICROPROCESSOR OPERATING COMPILER DHRYSTONES/SEC. * TYPE SYSTEM NO REG REGS * -------------------------- ------------ ----------- --------------- * Apple IIe 65C02-1.02Mhz DOS 3.3 Aztec CII v1.05i 37 37 * - Z80-2.5Mhz CPM-80 v2.2 Aztec CII v1.05g 91 91 * - 8086-8Mhz RMX86 V6 Intel C-86 V2.0 197 203LM?? * IBM PC/XT 8088-4.77Mhz COHERENT 2.3.43 Mark Wiiliams 259 275 * - 8086-8Mhz RMX86 V6 Intel C-86 V2.0 287 304 ?? * Fortune 32:16 68000-6Mhz V7+sys3+4.1BSD cc 360 346 * PDP-11/34A w/FP-11C UNIX V7m cc 406 449 * Macintosh512 68000-7.7Mhz Mac ROM O/S DeSmet(C ware) 625 625 * VAX-11/750 w/FPA UNIX 4.2BSD cc 831 852 * rosco_m68k 68010-8.0Mhz ROM gcc-7.5.0 - 862 (-O1) * DataMedia 932 68000-10Mhz UNIX sysV cc 837 888 * Plexus P35 68000-12.5Mhz UNIX sysIII cc 835 894 * ATT PC7300 68010-10Mhz UNIX 5.0.3 cc 973 1034 * rosco_m68k 68010-10Mhz ROM gcc-7.5.0 - 1086 (-O1) * Compaq II 80286-8Mhz MSDOS 3.1 MS C 3.0 1086 1140 LM * IBM PC/AT 80286-7.5Mhz Venix/286 SVR2 cc 1159 1254 *15 * Compaq II 80286-8Mhz MSDOS 3.1 MS C 3.0 1190 1282 MM * MicroVAX II - Mach/4.3 cc 1361 1385 * DEC uVAX II - Ultrix-32m v1.1 cc 1385 1399 * Compaq II 80286-8Mhz MSDOS 3.1 MS C 3.0 1351 1428 * VAX 11/780 - UNIX 4.2BSD cc 1417 1441 * VAX-780/MA780 Mach/4.3 cc 1428 1470 * VAX 11/780 - UNIX 5.0.1 cc 4.1.1.31 1650 1640 * Ridge 32C V1 - ROS 3.3 Ridge C (older) 1628 1695 * Gould PN6005 - UTX 1.1c+ (4.2) cc 1732 1884 * Gould PN9080 custom ECL UTX-32 1.1C cc 4745 4992 * VAX-784 - Mach/4.3 cc 5263 5555 &4 * VAX 8600 - 4.3 BSD cc 6329 6423 * Amdahl 5860 - UTS sysV cc 1.22 28735 28846 * IBM3090/200 - ? ? 31250 31250 *
It was really exciting to see these results - the rosco_m68k is the fastest 68000 in both the 8MHz and 10MHz categories :)
I will say again that the lack of an OS at the moment is probably a distinct advantage here, although these results were captured with the system timer tick running which does some memory access a couple hundred times a second and toggles a GPIO periodically, so it's not like there was nothing else going on - I like to think the results are in some way representative.
You can find the code along with the results in a text file here.
That is fun to see!
I have a VAX-11/750 (and I have the FPA board, but it double-functions as a heater, so that board is not installed). Cool to see that the 68010 ROSCO is next to the VAX in performance :)
