Small Constant current 20mA "Joule Thief"
It's not real Joule Thief. Rather step-up boost converter.
Starting from
$3.49
pnoxi has 167 orders / 17reviews
Ships from Slovakia
It's a small size (5x10mm) 20mA Step-Up CC LED Driver "Joule Thief" for LEDs.
Details:
Small size (5x10mm)
Fully assembled
The set current has a tolerance of +/- 3mA, depending on the input voltage, temperature, and component tolerance.
Output Voltage up to 15V (LEDs serial connection)
Maximum power dissipation 0.2W (25°C)! (Due to the small size of the PCB)
Automatic shutdown when voltage drops below 0.8-0.9V (No flashing)
No adjustment possible (voltage, current, frequency)
The switching frequency varies based on the input voltage. Approximately 300-500kHz.
PR4401:
  • 1x - PR4401
  • 1x - NRH2410T100MN
  • 1x - CC0603KRX7R7BB105
ZXLD381:
  • 1x - ZXLD381FHTA
  • 1x - WLPN242410M150PB
  • More detailed information
    Pnoxi06/23/2019 at 07:22 0 comments
    ZXLD381
    • Startup voltage: 0.9V
    • Maximum input voltage: 2.2V
    • 85% Efficiency
    PR4401
    • Startup voltage: 0.9-1V
    • Maximum input voltage: 2.0V
    • 80% Efficiency
View project log
Rich text editor
