This project is in a pretty early stage. I'm working on the prototype board. Lot's of design decisions are still to do. Any input or discussion is welcome.
Challenges are:
- The small form factor while having huge components like all the jacks and the stomp switch
- Signal to noise ratio must be high as guitars get highly amplified in later stages
- Should be not too hard to build
- Should be not too expensive
