Aquarium Light
Dinamic ligthing with oled screen and automatization options
Animal lighting was a very primitive technology ecosystem, like toasters, brands make them cheap instead of invest in quality and research, technology advance and now is very cheap add features and automatism that some time ago was prohibitive.
Adding LED lighting power consumption decreases and its more durable than conventional bulbs, and dimmable; a digital circuit can control automation for a very low price and give a nice user interface to control the basic parameters of the automatism like the time.
This light can folow the sun brightness, got sinusoidal light output according to a real time clock, giving the maximun light intensity at the zenit of the day.
It was designed to dont stress the fishes/reptiles/plants with inmediate sunrises or sunfalls, and to be unattended once its configured.
Designed to be easy to use, only one button, an encoder serves as navigation and selection button, easy on/off, upsidedown sensor to turn it off, with memory at all functions, autorestore in chase of temporaly interruption of electricity.
Functions:
  • Adjustable power
  • 5 Wachfaces
  • Timer (Summer&Winter)
  • Time, timer & power memory
  • Upsidedown sensor
  • Diffuse light output
Specs:
  • OLED Screen 1"
  • 4x5W Cold White COB LED
  • Power: 20W
  • Input: 220V
  • Aluminum case
  • 1 × Outer Shell Made - Workshop
  • 1 × Screen 3mm Frozen Made - Laser Cut 2
  • 1 × Inner Shell Made - Workshop
  • 1 × PCB Buy - Electronic Components 00
  • 2 × Pillar Made - Workshop
View all 44 components
  • Software
    Eduardo04/20/2019 at 19:49 0 comments
    Start screen:
    Double click to change it:
    Shield: This screen shows the output % in numbers and the decorative bars increses with the power to get a fast view.
    Neddle: This screen was designed to see the power output at large distances of the display.
    Volume: This screen was designed in order to be precise but graphical too.
    Clock: This screen shows the time, and the bar shows the power wit less priority.
    Timer menu: This screen shows the timer menu screen and time configuration, was designed to show all the info in once screen and to configure the device.
    Timer options:
    Summer and winter timers:
    Configurable sunrise and power:
    Setting the time:
  • PCB Assembly
    Eduardo04/19/2019 at 22:03 0 comments
    OSH Park purple looks so black on camera...
  • Force analysis
    Eduardo03/21/2019 at 14:10 0 comments
  • Thermal analysis
    Eduardo03/21/2019 at 12:05 0 comments
View all 4 project logs
  • 1
    Step 1
  • 2
    Step 2
  • 3
    Step 3
View all 38 instructions
