My new printer did not live up to expectations so I had to use the old one.
Here is a couple photos that will give you an idea.
As you know I'm making my custom motors for this and there are still problems with the small one, so there will be some delay.
I'm hoping however to install the mainboard and test sending commands, hopefully in my next update there will be some movement :)
