Yet another one of my projects ended up a focus of a HaD article, which works well as a motivational tool to get back on working on a project that's been pushed on the back burner. I'm happy to say that I have had a newer revision of the PCB made with the resistor placed across the buzzer as opposed to in series with it. I need to assemble it, then I'll post the KiCad files and Gerbers, and actual photos. I also need to try out the electrode flex PCB and post those files.
I'll be a bit busy for the remainder of this week, but I should be able to get around to the above tasks next week. I also wish I had a dedicated work area for my soldering station, hot air station, etc. Setting up shop in the kitchen is problem when others want to use the kitchen for it's original purpose.
