- The outer wall has to be set to subtract 1/4 of the inner wall value, to be the right value. So to get a 0.8mm outer wall, with a 0.8mm inner wall, you have to set it to 0.6mm.
- You need an odd number of 'rows' to have the hinges closed on both ends.
A project log for Parametric Box Generator
Populate two arrays and generate custom divided storage.
