The two bumps (spheres in the code) which are the latch and snap it closed could use to be slightly taller.
That's a bending interface and the force applied crosses layer lines, so a delicate balance must be struck.
<EDIT>
Fixed. New source and rendered files are up.
</EDIT>
MasterOfNull
