The support of iobroker is really awesome. Support of Paulmann switch controller 500.43 is integrated and will be available with next version of zigbee adapter 0.10.3.
Meanwhile I've tested a Xiaomi Aqara double switch successfully and a RGB LED controller of Paulmann 500.49 that works also fine only the teaching was a little bit tricky.
Since the last weeks two Osram smart+ plugs run without problems.
