![](https://cdn.hackaday.io/images/9533171598713129209.jpeg)
The three 55.6W drivers were installed. They connect to the mains through the relay, so that the LEDs are turned on or off by connecting the drivers to the mains.
A project log for UV Curing Chamber
A UV light curing chamber made with an old rack, some aluminum foil, and three 50W UV LEDS. An Arduino is used as a programmable timer.
