As discussed in a previous project log update, a way to solve the oxygen inhibition problem (other than just curing for longer times) is to remove oxygen from the surface of the part. An easy way of doing it is to submerge the part to be glued in a flask of water, if the bond and glue allow it.
A further reduction of the curing time can be achieved if the water is heated (with an inexpensive mains water heater for example) to accelerate the curing reaction.
Andrés Lopez Pulzovan
