Hardware
Brief characteristics of TFT shield:
- Size 3.5 " diagonal,
- Resolution 320x240,
- Number of colors 65536 (16-bit),
- Resistive touch screen (XPT2046 controller),
- 5 buttons,
- RTC IC DS1307 with 3V lithium battery CR1220,
- Slot for connecting a micro SD card,
- 4-pin (2.54 mm) connector for connecting the Bluetooth module HC-05 (-06),
- 20-pin (2.54 mm) connector for camera (OV7670).
Software
At the moment, the following library functions are implemented for working with graphics: drawing points, lines, circles, rectangles.The most popular library from Adafruit Industries was adapted for working with fonts. Additionally, work with the touch screen and buttons is implemented.Demo sketch to demonstrate the work with graphics and fonts:
#include <YATFT.h> // Hardware-specific library
#include <Adafruit_GFX.h> // Include Adafruit-GFX library
#include <Fonts/FreeSerif9pt7b.h> // Include Adafruit fonts
#include <Fonts/FreeSerifItalic24pt7b.h>
#include <Fonts/FreeSans24pt7b.h>
YATFT tft(0);
uint32_t total_time;
uint16_t Color[4] = {BRIGHTBLUE, BRIGHTGREEN, BRIGHTRED, BRIGHTYELLOW};
uint16_t Gray[7] = {GRAY0, GRAY1, GRAY2, GRAY3, GRAY4, GRAY5, GRAY6};
void ClearScreen (void)
tft.SetColor(BLACK); // Set fone color
tft.ClearDevice(); // Fill all screen
void setup()
Serial.begin(115200); // initialize the serial port
Serial.println("Arduino TFT_shield Example 1!");
tft.begin(); // initialize the display
void loop()
uint16_t x, y, x2, y2, mask_gray;
uint16_t i;
ClearScreen();
// Fonts
Serial.print("1) View Fonts (");
total_time = millis();
tft.SetColor(BRIGHTBLUE);
tft.SetFont(NULL);
tft.OutTextXY(5, 5, "Demonstration of work with the TFT display.");
tft.SetColor(BRIGHTGREEN);
tft.SetFont(&FreeSerif9pt7b);
tft.OutTextXY(5, 20, "The example uses fonts from Adafruit.");
tft.SetFont(&FreeSerifItalic24pt7b);
tft.SetColor(BRIGHTCYAN);
tft.OutTextXY(5, 45, "3,5''");
tft.SetColor(BRIGHTRED);
tft.OutTextXY(90, 45, "QVGA");
tft.SetColor(BRIGHTMAGENTA);
tft.OutTextXY(230, 45, "disp.");
tft.SetColor(BRIGHTYELLOW);
tft.SetFont(&FreeSans24pt7b);
tft.OutTextXY(5, 100, "A R D U I N O + T F T");
tft.SetFont(NULL);
for (i = 0; i < 7; i++)
tft.SetColor(Gray[i]);
tft.OutTextXY(5, 170+10*i, "Demonstration of work with the TFT display.");
total_time = millis() - total_time;
Serial.print(total_time);
Serial.println(" ms)");
delay(3000);
ClearScreen();
// Circle
Serial.print("2) Draw circle (");
for (i = 10; i < GetMaxY()>>1; i += 10) {
tft.DrawCirc(GetMaxX()>>1, GetMaxY()>>1, i);
delay(1000);
// DrawFillCircle & DrawFillRect
Serial.print("3) Draw FillCircle and FillRect (");
tft.DrawFillCirc(GetMaxX()>>1,GetMaxY()>>1,110);
tft.DrawFillRect(GetMaxX()/2-77,GetMaxY()/2-77, GetMaxX()/2+77,GetMaxY()/2+77);
tft.DrawFillCirc(GetMaxX()>>1,GetMaxY()>>1,77);
tft.DrawFillRect(GetMaxX()/2-54,GetMaxY()/2-54, GetMaxX()/2+54,GetMaxY()/2+54);
tft.DrawFillCirc(GetMaxX()>>1,GetMaxY()>>1,54);
tft.DrawFillRect(GetMaxX()/2-37,GetMaxY()/2-37, GetMaxX()/2+37,GetMaxY()/2+37);
delay(1000);
ClearScreen();
// Arc
Serial.print("4) Draw Arc (");
ClearScreen();
tft.DrawArc((GetMaxX()>>1)-60,(GetMaxY()>>1)-60,(GetMaxX()>>1)+60,(GetMaxY()>>1)+60,20,30,0xFF);
tft.DrawArc((GetMaxX()>>1)-40,(GetMaxY()>>1)-40,(GetMaxX()>>1)+40,(GetMaxY()>>1)+40,20,30,0xFF);
tft.DrawArc((GetMaxX()>>1)-20,(GetMaxY()>>1)-20,(GetMaxX()>>1)+20,(GetMaxY()>>1)+20,20,30,0xFF);
delay(1000);
Serial.print("5) Draw FillBevel (");
tft.DrawFillBevel((GetMaxX()>>1)-60,(GetMaxY()>>1)-60,(GetMaxX()>>1)+60,(GetMaxY()>>1)+60,30);
tft.DrawFillBevel((GetMaxX()>>1)-40,(GetMaxY()>>1)-40,(GetMaxX()>>1)+40,(GetMaxY()>>1)+40,30);
tft.DrawFillBevel((GetMaxX()>>1)-20,(GetMaxY()>>1)-20,(GetMaxX()>>1)+20,(GetMaxY()>>1)+20,30);
delay(1000);
ClearScreen();
Serial.print("6) Draw Arc (");
for (i = 0; i < 4; i++) {
tft.SetColor(Color[i]);
tft.DrawArc((GetMaxX()>>1),(GetMaxY()>>1)-50,(GetMaxX()>>1),(GetMaxY()>>1)+50,50,60,0x11<<i);
tft.DrawArc((GetMaxX()>>1),(GetMaxY()>>1)-30,(GetMaxX()>>1),(GetMaxY()>>1)+30,35,45,0x11<<i);
tft.DrawArc((GetMaxX()>>1),(GetMaxY()>>1),(GetMaxX()>>1),(GetMaxY()>>1),20,30,0x11<<i);
delay(1000);
ClearScreen();
// Draw 1000 random lines
Serial.print("7) Draw 1000 random lines (");
for (i = 0; i < 1000; i++) {
tft.SetColor(random(65535));
x = random(GetMaxX());
y = random(GetMaxY());
x2 = random(GetMaxX());
y2 = random(GetMaxY());
tft.DrawLine(x, y, x2, y2);
delay(1000);
Serial.print("8) ReDraw 10 Fill Screen (");
tft.SetColor(BRIGHTBLUE); // Set fone color
tft.SetColor(YELLOW); // Set fone color
tft.SetColor(BRIGHTGREEN); // Set fone color
tft.SetColor(BRIGHTRED); // Set fone color
tft.SetColor(BRIGHTCYAN); // Set fone color
tft.SetColor(GREEN); // Set fone color
tft.SetColor(BRIGHTYELLOW); // Set fone color
delay(1000);
A demo sketch to demonstrate how to work with fonts and a touch screen:
#include <SPI.h> // Include SPI library
#include <XPT2046_Touchscreen.h> // Include Touchscreen library
// Touchscreen: MOSI=11, MISO=12, SCK=13, CS=2
#define CS_PIN 2
XPT2046_Touchscreen ts(CS_PIN, 255);
YATFT tft(0);
#define Y_BAR_TOP (GetMaxY()-50)
#define Y_BAR_BOT GetMaxY()
#define BUTTON1_MASK 0x01
#define BUTTON2_MASK 0x02
#define BUTTON3_MASK 0x04
#define BUTTON4_MASK 0x08
#define BUTTON5_MASK 0x10
If using the shield, all control and data lines are fixed, and
a simpler declaration can optionally be used:
//uint32_t total_time;
uint16_t pos_x[] = {0,0,0,0};
uint16_t pos_y[] = {0,0,0,0};
uint8_t pos_x_cnt = 0;
uint8_t pos_y_cnt = 0;
uint16_t pos_x_mid = 0;
uint16_t pos_y_mid = 0;
uint16_t color_paint = WHITE;
uint8_t buttons = 0;
void setup()
Serial.println("Arduino TFT_shield Example1!");
ts.begin(); // Init Touchscreen
SPI.end(); // Disable SPI for correct work DB2 (SS) pin
RefreshWindow();
void loop()
uint16_t x, y;
// Touch
// When the SS pin is set as OUTPUT, it can be used as
// a general purpose output port (it doesn't influence
// SPI operations).
SPI.begin();
if (ts.touched())
TS_Point p = ts.getPoint();
Serial.print(F("Pressure = "));
Serial.print(p.z);
Serial.print(F(", x = "));
Serial.print(p.x);
Serial.print(F(", y = "));
Serial.print(p.y);
Serial.println();
delay(3); // Delay for filtering
// Calculate coordinates x, y from code ADC
if (p.x < 200) p.x = 200;
if (p.y < 250) p.y = 250;
#if 0
x = (uint16_t)(320L - ((uint32_t)p.x - 200L)*10L/115L);
y = (uint16_t)(((uint32_t)p.y - 250L)/15L);
#else
x = (uint16_t)(0 + ((uint32_t)p.y - 200L)*10L/115L);
y = (uint16_t)(((uint32_t)p.x - 250L)/15L);
#endif
// Filtering
pos_x_mid = (pos_x[0] + pos_x[1] + pos_x[2] + pos_x[3])/4;
pos_y_mid = (pos_y[0] + pos_y[1] + pos_y[2] + pos_y[3])/4;
pos_x[pos_x_cnt++] = x;
pos_y[pos_y_cnt++] = y;
pos_x_cnt &= 0x03;
pos_y_cnt &= 0x03;
if (x > (pos_x_mid - 10) && x < (pos_x_mid + 10) && y > (pos_y_mid - 10) && y < (pos_y_mid + 10 )) {
if (y > Y_BAR_TOP && y < Y_BAR_BOT) {
if (x < 1*(GetMaxX()+1)/5) { // Touch Bar 1
color_paint = Color[0];
RefreshTitle();
} else
if (x < 2*(GetMaxX()+1)/5) { // Touch Bar 2
color_paint = Color[1];
RefreshTitle();
} else
if (x < 3*(GetMaxX()+1)/5) { // Touch Bar 3
color_paint = Color[2];
RefreshTitle();
} else
if (x < 4*(GetMaxX()+1)/5) { // Touch Bar 4
color_paint = Color[3];
RefreshTitle();
} else { // Clear screen
RefreshWindow();
} else {
tft.SetColor(color_paint);
tft.DrawFillRect(x-1, y-1, x+1, y+1);
ScanKey();
void RefreshWindow(void)
ClearScreen();
for (uint8_t i = 0; i < 4; i++) {
tft.DrawFillRect((i+1)*((GetMaxX()+1)/5), Y_BAR_TOP, (i)*((GetMaxX()+1)/5), Y_BAR_BOT);
RefreshTitle();
tft.SetColor(WHITE);
tft.OutTextXY(GetMaxX() - 50, GetMaxY() - 45, "Clear");
tft.OutTextXY(GetMaxX() - 55, GetMaxY() - 25, "screen");
void RefreshTitle(void)
tft.OutTextXY(3, 20, "Touch color bar and screen or press key.");
void ScanKey(void)
static uint8_t buttons_last = 0;
buttons = tft.scanButtons();
if (buttons != buttons_last) {
if (buttons & BUTTON1_MASK) { // Bar 1
RefreshTitle();
if (buttons & BUTTON2_MASK) { // Bar 2
RefreshTitle();
if (buttons & BUTTON3_MASK) { // Bar 3
RefreshTitle();
if (buttons & BUTTON4_MASK) { // Bar 4
RefreshTitle();
if (buttons & BUTTON5_MASK) { // Clear screen
RefreshWindow();
buttons_last = buttons;
Demonstration
Below is added a video demonstrating the work of sketches. To be continued.
P.S. If you like or are interested in this topic, please rate my article. Perhaps your assessment will speed up the next article. :-) Thanks for attention.
